Overview
To select which 2 signals to display on an XY-Graph.
Description:
I have created a VI which allows the user to select 2 signals to display on an XY Graph. The way the code works is by using the 'Select Signals' Express VI. This VI allows you to pass out signals specified by passing a 0.5 into the 'selector' input in the same index as the required signal. The signals can be selected by enumerated controls which can be populated with the user's signal names.
Instructions:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
Hardware
