Overview
This VI rotates Input Array by cyclic left shifting every Array element and creates a reversed Output Array
Description
The Output Array is being initialized first. Then in each loop iteration, it is being rotated and an input element is being inserted to the beginning, and lose the last element so the array stays the same size.
It does this by rotating the array so each element moves up one index except the last value moves to the first index (index 0). This is then over written by the new value.
Requirements
LabVIEW Full Development System 2012 or compatible
1.Run the VI
2.Observe how the Array elements are being rotated right
Note: You can change the colors of the Input Array elements
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
