Overview
The example is to demonstrate the use of the Analog Trigger to initiate the retriggerable instance of the Analog Output
Description:
This VI would offers the solution with the DAQ device that do not support retriggerable IO by using two onboard counters to generate retriggerable pulse trains that would be used for sample clock for the analog output task. The VI would use the analog PFI line (API0) to trigger the analog output task that eventually sends a trigger to the counter output task.
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Analog Output and Counter Output Module
The program works just as it says. For my application, setting the cycles to buffer to 1 and samples to buffer to 50 allows me to generate a pulse of ~15microseconds whenever the analog trigger is set off.
I am using Labview 2011 and it can't find Waveform Buffer Generation.vi
With each new release of LabView you will need to direct the older VI's to the new folder.
It will be here:
C:\Program Files (x86)\National Instruments\LabVIEW 2011\examples\DAQmx\_Utility
The LLB manager will show the needed VI's. Select on the VI and then OK the referance change.
