Overview
When creating a headless data logger, it can be preferable to have swappable data storage devices, leading to the use of an external USB Hard Drive etc. It is also preferable to be able to check the state of this drive especially when connecting new drives in a headles environment.
Description
This VI uses some of the advanced file functions to very simple effect - by pointing it at the USB port of the Real Time Controller, they will report Error 7 if the USB Storage is not available (this could lead to further custom error handling if needed).
As a visual cue, for a headless system, this then causes the RT LED to flash a warning to the user (that can be customised per error)
Requirements
Software
LabVIEW 2013 (or compatible), LabVIEW Real-TIme Module
Hardware
NI cRIO 9025 in this case but any NI RTOS Target is fair game
- Create Real Time project
- Add the the VI under the RT Target
- Disable/Delete any of the error handlers you don't want
- Press Run!!
Additional Information or Reference
Liam A.
