Overview
This example VI provides a method to set block diagram passwords for all VIs in a LLB or folder.
Description
This example VI can set block diagram passwords for all VIs in a LLB or folder, it is convenient to help you protect numerous VIs that you'd like to password-protect. You can also remove a password by setting the Lock State on the VI Invoke Node to "Not Locked", then enter the password that the VIs were originally locked with into the Password string.
In order to remove the password from VIs in a LLB or folder immediately after applying a password, you may first have to restart LabVIEW in order to remove the VIs from memory.
Requirements
VI Snippet
