Example Code
Programmatically Find IP & MAC Address of Devices on Network Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI uses the System Configuration API to query MAX for the Hostname, IP address, and MAC address of each relevant item on your network.
Description
This VI returns the data as an array of the Hostname, IP address, and MAC address.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI.
  2. See the Hostname, IP address, and MAC address of each relevant network item on the front panel.
VI Snippet
Fred Visser -- SystemLink R&D -- National Instruments
Comments
wsaall
on
I have LV 2009, how I can use it?
Could you please show the VI's name so I can search for it.
