Example Code
Programmatically Enable/Disable RT Startup Application Using RealTime for LabVIEW
Products and Environment
    Hardware
  • CompactRIO|SingleBoardRIO
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Overview
This VI is an example of how the ni-rt.ini file can be modified on a Real-Time controller programmatically from a host PC.
Description
The VI should be run from a host PC; it uses WebDAV to copy the controller's ni-rt.ini file to a specified location on the host, edits the StartAppAtBoot token, and then uses WebDAV to replace the ni-rt.ini file on the controller with the new settings. This VI is designed to work with a Linux RT controller such as the myRIO or cRIO-9068, to use it with a VxWorks target, you will need to change the path to the ni-rt.ini file.
Requirements
Software
LabVIEW 2013 (or compatible)
LabVIEW System Configuration API
LabVIEW Real-time module
Hardware
A Linux RT Target (other targets possible but changes will need to be made.)
  1. Ensure you have a connection to a Linux RT target.
  2. Choose your target using the "Session In" dropdown box. Depending on your controller settings, you may have to initialize your connection first with the appropriate login information.
  3. Change the boolean control on the front panel to either disable or enable the RT Startup App.
  4. Run the VI
Additional Information or Reference
DisableStartupApp 2013 NIVerified Block Diagram
After pressing "StartupApp?" ni-rt.ini file.
If not press "StartupApp?" ni-rt.ini file.
Rob B
FlexRIO Product Manager
Comments
PrimaryKey
NI Employee (retired)
on
Looks really usefull. Good job!
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
