Overview
This VI demonstrates how to programmatically center an object on the front panel based on the window's size.
Description
This VI takes the size of the window and then positions the Object in the middle of the coordinates. It is really a demonstration of how you could build this into your own code. You can then create your own positioning, playing around with the coordinates, and place additional objects.
Requirements
LabVIEW Full Development System 2012 or compatible
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Thanks for posting!
If I have a group of objects, it would be tedious to repeat the same "Waveform Graph" procedure to center each object. Is there a better way ?
cha@bellflight.com
