Overview
This example demonstrates how to overlay the reading of a barcode on top of the center of the barcode in Vision Builder for Automated Inspection 2009.
Description
Vision Builder for Automated Inspection allows you to load inspect and process images in a configuration based invorment.
Requirements
Vision Builder for Automated Inspection 2009 "or compatible"
Steps to Complete
This example involves the following steps:
1) Read the barcode
2) Locate the center of the barcode
3) Write the position values of the center to variables
4) Read these variables in the overlay step to overlay the readings on the center of the barcode
Need VBAI 2009 to run this example. Attached is a sample barcode to read. For different barcodes, the setting for the 'Read Data Matrix Code' may have to be changed.
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Thanks for sharing, but does this bar code scanner can scan both linear and 2d bar code and read bar code from .net project?
