Overview
Coding that exemplifies how to generate a GSM and EDGE signals.
Description
GSM-EDGE Toolkit has two RFSG Databases, one for GSM Generation and second for EDGE Generation. Attached example shows how you can generate multi-standard (GSM and EDGE) signals, using either of these two databases.
Requirements
LabVIEW 2012 (or compatible)
1. Select the Resource Name and Frequency Control.
2. Review the rest of the configuration parameters for the GSM and EDGE generation.
3. Configure the script as desired.
4. Run the VI.
5. use the Stop button to finalize the generation.
