Overview
This code allows the user to customize the Initialization VI when configure Look-Up Table 1D Express VI.
Description
Look-Up Table 1D Express VI contains a LUT for an arc sine function. The LUT takes a value for sin(theta) in the range of 0 to 1023 which corresponds to values of sin(theta) between -1 and 1. The output of the LUT is the value of theta between -512 and 512 which corresponds to theta values between -pi/2 and pi/2. The image below shows the block diagram example using the LUT.
If anything needs to be changed with respect to the domain, range or resolution of the LUT, this VI can be used to initialize the LUT with the proper values.
Requirements
LabVIEW 2012 (or compatible)
LabVIEW FPGA 12 (or compatible)
- Set Memory Block Size
- Run VI
- This VI could be call from Look-Up Table 1D Express VI
