Example Programs
IMAQdx: Save IMAQdx Sequence to AVI File
Overview
This example acquires a sequence of images using IMAQdx Sequence.vi then creates an AVI file to save the sequence.
Description
This VI first creates a camera session and an AVI session.  Then, a buffer is created for each image in the sequence using IMAQ Create in a for loop.  Next, the images are acquired and stored in the buffers.  The images are then pulled from the buffers and saved as an AVI file.  Last, the sessions are closed.
Requirements
Software
LabVIEW 8.0 "or compatible"
Vision Acquisition Software 8.0 (NI-IMAQdx) "or compatible"
Hardware
Camera compatible with NI-IMAQdx (Firewire, Gigabit Ethernet, USB, etc.)
  1. On the front panel select the camera under 'Camera Name'.
  2. Configure number of images in the sequence and the fps.
  3. Under 'Selected Path' type the desired file path for the saved AVI file.
  4. Run the VI
VI Snippet
This code was tested using a FireWire camera at 30fps.
NI-IMAQdx Compatibility with Different LabVIEW Versions
Is My Camera Supported by National Instruments?
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Contributors
