Overview
This example shows how to generate four pulse trains of the same frequency and out of 90 degree phase on cDAQ 9178.
Description
The CompactDAQ 9172 chassis has 2 counters on the back plane. This limits the user to 2 separate pulse train generation tasks for all modules on the chassis. This example program demonstrates the use of correlated digital output to create 4 pulse trains of the same frequency that are 90º out of phase. This example was written for the NI-9401 High-Speed Bidirectional Digital I/O Module, but may work with other modules as well. Please note that the module must be in slot 1,2,3, or 4 for this example to run.
Requirements
Software
Hardware
1.Insert NI-9401 into 1,2,3 or 4 slot of cDAQ 9178.
2.Configure the following settings in the block diagram.
(1)Select the port to output pulse trains.
(2)Set the frequency you want to generate
3.Run the VI.
