Example Code
Flexible DAQmx State Machine for Automated Tests
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI shows how to use a State Machine with an array of steps to run throguh a pre configured list of steps.
Description
This Example shows a process where we turn a heater on, then measure a finite numer of samples then tunr the heater off.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Set the Physical Channels for a digital output and analog input.
  2. Configure the Steps from a list of States dropdown.(to add new states right-click the dropdown and select Open Type Def and Edit the Elements)
  3. Set the Numer of Samples thenrun the VI
Comments
Philip1
on
This looks like exactly what I need.
I am using LabVIEW 2010 base. Is the base package enough to run this VI??   I am informed (while loading) that "State Type def .ctl" is missing (or isn't where its should be).
Thank you-
Tiger3D
on
Please add "State Type def .ctl". Otherwise it looks great. Thank you.
JTShaw
on
Please add "State Type def.ctl"
HunterSeeker
on
I added the type def, should be good to go now.
