Overview
This VI shows how to use a State Machine with an array of steps to run throguh a pre configured list of steps.
Description
This Example shows a process where we turn a heater on, then measure a finite numer of samples then tunr the heater off.
Requirements
Software
Hardware
This looks like exactly what I need.
I am using LabVIEW 2010 base. Is the base package enough to run this VI?? I am informed (while loading) that "State Type def .ctl" is missing (or isn't where its should be).
Thank you-
Please add "State Type def .ctl". Otherwise it looks great. Thank you.
Please add "State Type def.ctl"
I added the type def, should be good to go now.
