Overview
This example VI Demonstrates the use of Build Path and Stripe Path functions to find next available file path name by appending a number to the file path.
Description
This VI will take in a file Path that points to a .csv file, and if that file already exists, it will append a number to the end of the file name and recheck until it finds a valid file name that is not in use. For example if Path points to test.csv, if test.csv does not exist, Path Out will be test.csv, but if test.csv already exists, Path Out will be test1.csv, and if that exists it will be test2.csv and so on.
Requirements
VI Snippet
Thanks, this is just what I was looking for!
