Overview
To dynamically set a waveform chart's x-axis minimum and maximum value based on the sample rate and the number of samples per channel.
Description:
This example shows how to dynamically set a waveform chart's x-axis minimum and maximum value based on the sample rate and the number of samples per channel. The x-axis is also set to start at a relative time of zero. The example is setup to read and display 3 channels.
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Input Module
