Overview
This example demonstrates how to create an 8 channel pulse delay generator with the PXI/PCI-6602.
Description
This delay generator creates a series of pulses at different delays on each channel from a common trigger.Delay generators are often sold as stand-alone devices - here we are purposing a counter/timer board to act as a delay generator. The inputs are being presented in terms of Pulse Width, Duty Cycle, and Initial Delay in seconds, not in terms of ticks. This example will also work with the PXI-6608.
Requirements
Software
Hardware
1. Load the Delay Generator LV_82.vi
2. Specify the counter, pulse width, duty cycle, and initial delay for each channel.
3. Set up the trigger source. The other values trigger parameters will usually remain constant.
4. Run the VI and send the 6602 a trigger on the trigger source channel.
This appears to generate multiple pulse trains all relative to a single trigger edge. Repeated triggers will have no effect on subsequent pulse train generations (even with the retriggerable property enabled), because the counters are already generating pulses (and thus the retrigger is ignored).
Am I understanding this correctly?
