Example Programs
DAQmx Change Detection Event Registration
Overview
This code demonstrates how to capture both the rising and falling events associated with change detection.
Description
This code demonstrates how to capture both the rising and falling events associated with change detection.  By adding the boolean logic, you can now have seperate actions based upon the rising or falling edge of a signal.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
1. Select the physical lines and connect signal.
2. Run the program.
A_Ryan
AES
Comments
Member Jeff_Long
Member
Very nice example of using change detection with events!  I used this today with a USB-6525 to detect a 10ms pulse from a host machine as a start signal for my software application.
Jeff Long, President
AutomationWorks, Inc.
http://www.automationworks.com
Member Gardo
Member
-- Author has updated example adding Unregister--
Thanks.
Member Åland
Member
 Is it by any chance possible to get this example to work with USB-6003?
I want to fire an event when a digital in pin go HI.
I tried this example but get an error message saying
Requested value is not a supported value for this property.
The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Change Detection
Possible Values: On Demand
Member Titen
Member
Hardware Compatibility Note:
Not all DAQ hardware supports Change Detection. Please view the following KB to see if your device is compatible
