Example Code
Create Partial Transparent Image Overlay Without VDM
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to create a partial transparent overlay over an image without the Vision Development Module (VDM).
Description
When trying to create transparent portions of images using the Picture Functions in LabVIEW, your only option is to the Create Mask function. However, it does not allow for partial transparency.
The work around to achieve partial transparency is to average the pixels you would like to be transparent with the pixel values of the original image. See the attached VI for an example of performing this feature.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached ZIP-file
  2. Open and run the [Main] ...VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Alex Person
NI-RIO Product Support Engineer
Comments
Torben Oestergaard-Andersen
on
Great !!
Thanks - this wa sjust what I needed 🙂
