Overview
This VI allows us to quickly convert a single VI or a whole folder full of VIs to a previous version to provide compatibility.
Description
Often when developing applications we need to be save applications to previous version in order to move them from one system to another. This applications allows you to select a VI and convert that VI to a previous version. The benefit of using this application is that you are not limited converting a single VI at a time and can actually convert whole folders of LabVIEW code to a previous versions.
Requirements
- LabVIEW 2012 (or compatible)
- Unzip the attached folder to your computer
- Open the project "ConvertToPrevious 2012 NIVerified.lvproj"
- Run the "Main VI".
VI Block Diagram
Aaron. E
Product Performance Engineer
Dyson
