Overview
Creating a software timed continuous analog output signal with the USB-6008/6009.
Description
This program demonstrates how to perform continuous analog output tasks on the USB-6008 / 6009 and also incorporates the theory of operation that is associated with software timed analog output. Continuous software timed analog output means that your analog channel will update only once for every iteration of the program's while loop. It is important to remember that these devices allow a maximum update rate of 150 samples per second on each channel; therefore the main program's while loop can iterate no faster than once every 6 ms.
It is also important to remember that these devices allow an output voltage range of 0 to 5 Volts. For demonstration purposes, this program outputs a sine wave with a DC offset of 2.5V and allows the user to select the number of points per cycle. It will be observed that increasing the points per cycle will increase the resolution of the output waveform, but also decreases its frequency. The approximate period of the output waveform is equal to the points per cycle times the output rate.
1. Open the ContinuousAnalogOutUSB60086009 VI
2. Configure front panel controls
3. Run the VI
Requirements to Run
Software
LabVIEW 7.1 or later
DAQmx 7.1 or later*
*Driver version must be compatible to your version of LabVIEW
Hardware
USB-6008 or USB-6009
Additional Images
Block diagram
Dan King
I tried loading your program, but it can't find any of the dll's. Where do I get them?
Hi WSOCT,
You will need the DAQmx driver to be able to see/use these VIs you see as question marks.
You can download the DAQmx driver from our website at www.ni.com/drivers.
I just ran an experiment where I set up a 5V, 0V, 5V, 0V ... pattern using a USB-6008. Whether I used an analog output or digital output, it generated approximately a 1 kHz pattern on my scope. How is that possible if it only updates at 150 samples/second?
I tried to run this program using a 6008. it did not run. the error was
no transfer is in progress becuase the transfer was aborted by client. the operation could not be completed as specified. unnamed task ,0.
(Ignore that there is an empty output in the blunde). I want to generate through NI USB-6009 a 60Hz sine wave. I play with the parameters "Frequency" and the constant in the wait VI. I am using a multimmeter to measurer the AC Voltaje and the frequency at the Analog output of the NI USB-6009, but the frequency is not constant and it varies from 30Hz to 44Hz very fast or from 55Hz to 90Hz. What do you recommend me to obtain a constant frequency in the NI-USB 6009 analog output?
Hello. I am trying to create output for 2 channels ( x and y). How can I modify the program to make it possible to have 2 sine waves for 2 channels?
