Example Code
Continuous Analog Acquisition That Logs Data After Receiving Digital Pulse
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI sends a digital trigger to a counter line that will trigger your VI to begin logging data from your continuous analog acquisition task.
Description
  1. Create one analog input task and one counter input task.
  2. Configures the sample clock for the analog input task.
  3. Begin the acquisition of the counter then the analog input.
  4. Continually reads the data until the counter sees a rising edge then the analog input data is logged to file.
  5. Clears the task, merges errors, and reports any errors that occurred.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device with at least one counter
  1. Download the VI
  2. Select the following controls on the front panel
    • Physical channel of analog input
    • Counter channel
    • Sample rate
    • Maximum value
    • Minimum value
  3. Run the VI
  4. See log file for data after running VI
Adam
Academic Product Manager
National Intruments
