Overview
The attached program lets you print the front panel of a VI using printer settings configured from the Windows Print Dialog.
Description
There are many times you would like to customize the way documents are printed in LabVIEW, but you have to create your own dialog for display to configure these options. The attached program lets you print the front panel of a VI using printer settings configured from the Windows Print Dialog.
Print Front Panel.vi uses calls to the Microsoft .NET framework to display the Print Dialog window and retrieve settings made in the dialog to configure how the front panel of a VI is printed. VIs from the Report Generation palette are used to capture the front panel and set the report for the desired orientation, margin size, printer used and number of copies, however you do not need the Report Generation Toolkit installed to use this example.
Requirements
LabVIEW 2012 (or compatible)
- Run the application as subvi.
VI Snippet
Donovan
