Example Code
Analog Input - Synchronization (Sample Clock, Reference Clock, Start Trigger)
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
The example gives the different options to synchronize DAQ cards using DAQmx
Description
This example is intended to show low level synchronization of various devices. DSA, S Series, X Series, and SC Express devices support including channels from multiple devices in a single task. DAQmx automatically synchronizes the devices in such a task.  See the DAQmx Help>>Device Considerations>>Multi Device Tasks section for further details.
*Note: The example was tested succesfully with LabVIEW 2013, and a PCIe-6363 connected with a NI PCIe-6351 using a RTSI cable which was created before in NI-MAX.
Requirements
Software
  • LabVIEW 2013 (or compatible)
  • DAQmx 9.7.5 (or compatible)
 Hardware
Two or more NI DAQ devices as DSA, S Series, X Series, and SC Express devices
  1. Download both attach VI´s and paste them in the same carpet.
  2. Connect two DAQ cards, f.e. the PCIe-6363 and the PCIe-6351 to the computer.
  3. Use a RSTI cable to connect both cards.
  4. Ensure the cards are working with NI-MAX.
  5. Select the cards as Master and Slave.
  6. Select the Synchronization type (Read the **Note).
  7. Set timing settings correctly.
  8. Select the type of synchronization you want to execute (Read Note 2 and Note 3).
VI Snippet
