Overview
The example is to demonstrate how to generate three analog signals with user defined delay programmatically
Description:
This VI would shows you how to generate three identical origin of a signal with applied delays by the user. This is achieved by altering the time element of the waveform of the generated waveform made programmatically within the LabVIEW. By altering the time, we could utilize some delays to the signals
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Analog Output Module
It could be nice to download it, or see the block diagram..
Hi Fred,
Sorry forgot the attachment!
Thanks for the heads up.
Scott M
