Overview
This example VI shows how to log one value every second and 60 values average every minute.
Description
This VI iterates one loop for second. A random value is generated every loop iteration and put into the array. The random value is also written to a spreadsheet file. The loop executes the true case once every minute. Inside this case the array of values gets averaged and that average value is written to a spreadsheet file.
Requirements
- LabVIEW 2012 (or compatible)
- Open the VI
- Select the path o create new log files
- Run the program
VI Block Diagram
