Overview:
A Routine to find a value without having to ramp up to find the desired value.
Description:
This routine will quickly find a value that meets the requirements for a test condition, without ramping up through many values.
Hardware and Software Requirements
LabVIEW 2017 Full Development System 2017 or compatible.
Set values for Maximum Control Value, Minimum Control Value, Target, and Number of Passes.
Inside of the Loop, output Test Value, then read the result. Connect the result to the lower input of the Compare icon.
The displays Iteration, Test Value, and Shifting Value are used for testing and debugging the routine.
