Overview
The example demonstrates how to retrieve all VeriStand System Definition without the need of deploying
Description:
Currently the VeriStand API allows you to retrieve all channels through the Get System Node Channel List.vi, a wrapped VI utilizing the VeriStand Client API. This API is used to automate the operation of the application on the execution host. However, there are some instances where one would like to obtain the channel list without needing to deploy the system definition. One such example is building an Alias text file for a large number of channels. In order to do this, the System Definition API must be used.
Steps to implement or execute code
To implement this example:
Requirements
Software
LabVIEW 2012 or compatible
It's a very useful program. It works well but I need more information about channels.
I just change it to see DAQ, FPGA and Custom device channels. Is there a way to see if the channel is an input or an output ?
Best regard,
Hervé
