Example Program Drafts
Programmatically Download a File From The Internet Using LabVIEW
Overview
This example shows how you can download a file from the internet, programmatically.
Description
This example allows you to communicate with the download server directly, using the HTTP GET protocol.
Hardware and Software Requirements
LabVIEW 2016 or compatible.
  1. Download and open the code.
  2. Put in the download URL in the control.
  3. Specify the local directory to place the downloaded file.
  4. Run the VI.
This has been tested to download the file from NI's download link:
http://download.ni.com/support/softlib/high_speed_digitizers/niscope/Patches/NI-SCOPE%204.0%20Calibr...
After running the code, the MD5 checksum is verified to be correct.
Contributors
