Example Program Drafts
LabVIEW / Measurement I/O / NI-DAQmx / VI / NI USB-6002 / DAQ / Multifunction Device / Analog Input (AI)
Overview
Input is given to AI port by function generator of frequency 10 Hz and amplitude 4Vpp. The input range is -2 V to +2 V. For the analog input mode, the user has the option to select the DAQmx Global Channel.
Description
There are two configurations in analog input in NI DAQ-
  • Differential mode, the device measures the difference in voltages between two AI.
  • Reference single-ended mode (RSE), where the voltage of AI signal with respect to the ground.
Hardware and Software Requirements
 NI USB-6002, LabVIEW
 1. Connect USB-6002 through USB port.
 2. Input is given to AI port by function generator of frequency 10 Hz and amplitude 4Vpp. The input range is -2 V to +2 V.
 3. Download NI-DAQmx 18.0.0, Execute sample code "USB6002-AI0S" and run it.
 4. Monitor the waveform.
Contributors
