Example Program Drafts
Example of niVB_MSO_ForceTrigger Virtual Bench CVI programming
Overview
The proper circumstance where a call to Force Trigger would be effective will be when you have your system waiting for an Analog Trigger, however, somehow this trigger does not come along. Using the Force Trigger function, you can simulate the Analog Trigger and start your task.
The Auto Trigger must be disabled to ensure that the Force Trigger functionality is set correctly.
Description
 This code shows how to properly use the Force Trigger function and get as a result a "Forced" as Trigger Reason.
Hardware and Software Requirements
LabWindows/CVI
Virtual Bench
 - Connect the Virtual Bench
 - Make sure that the device name is declared properly
Comments
Member A-Guz-Man
Member
Great example!
Member azp7
Member
Great work!
Contributors
