Overview
This code allows the user to modify the TDMS properties without using Diadem.
Description
This VI uses a Event Structure with a couple of Events: Edit Property Value and Continue (Value Change). When user fires the Edit Property Value (Value Change) a Dialog Box appears. When the user types the new Value it will be modify the original TDMS File using TDMS Set Properties.
Requirements
LabVIEW 2012 (or compatible)
