Example Program Drafts
Channel Expansion using DAQmx in LabWindows™/CVI
Overview
 This example demonstrates DAQmx channel expansion in LabWindows™/CVI.
Description
This code takes data from three channels on a cDAQ, over two modules.The channel expansion is done in both the .uir file and in code. In the UIR file, the second channel is added by adding a comma after the first channel. In the C source file, all of the channels are configured together using two subsequent DAQmxCreateAIVoltageChan function calls. When the code is run, a graph with the three signals populates.
Hardware and Software Requirements
LabWindows™/CVI 2017 and DAQmx 2017
- Simulated or physical cDAQ with two analog voltage input modules.
1. Ensure that you have simulated or connected a cDAQ with two analog voltage input modules.
2. Download and unzip the project.
3. Open and run the project.
Claire M.
Applications Engineering
Certified LabVIEW Developer
Contributors
