Overview
This example is a modification of the shipped 579x project that allows a 5791 to perform record and playback.
Essentially the starting project is merged with the High Throughput example for the VST here : https://decibel.ni.com/content/docs/DOC-26426
Description
Starting from the 579x project, this example extends the system to perform record and playback.
The 7966R and the 7975R are subtly different, using different CLIPS - the 7975R uses the latest CLIP - the only difference is in the naming of the sample clock (or data clock) and the x2 variants.
Compiling the 7975R also includes the PCIe interface in the background, so this compilation will take longer than for the 7966R version.
Requirements
Software
LabVIEW 2014
Hardware
7975R with a 5791 or a 7966R. (Other FlexRIO modules are available, however the speed that the 5791 can run at makes compiling for other targets more difficult. Recommend the 7962R, and the 7976R as alternatives.
Additional Images or Video
I've used this code without the "Record and Playback feature", so I just transmit data from one device to another. Is it possible to realize multi channel support? So that I can transmit messages e.g. on 2 channels after each other in a specific timing?
greets
Thomas
