Overview
This code allows the user to do a Polynomial Fit with three dimensional data. Then using the calculated Polynomial Coefficients and two known parameters, it Interpolates the third unknown parameter.
Description
The Main VI implements a State Machine that is handle by the Cluster.
Click the Calculate Coefficients button to calculate the Polynomial Coefficients based on the 3D Input Data Arrays (X,Y and Z) and the desired order.
Click the Interpolate button to find an unknown Z based on a known X and Y, as well as the calculated Polynomial Coefficients.
Requirements
LabVIEW 2012 (or compatible)
Exactly what i needed, thanks!
