Introduction
This community example briefly looks at how to acquire real world EEG data in LabVIEW using the Biomedical Toolkit add-on. The VI is included at the end of this document and makes use of both the Biosignal DAQ express VI and the EEG FFT Spectrum VI of the Biomedical Toolkit. This example is the second in a series of example programs that make use of the toolkit to acquire biosignals in the real world.
Uses of simulating EEG data
Simulating signals is a good way to check the behavior of your program before acquiring real world data. It is also a good measure of what sort of amplitudes and frequencies to expect when performing the acquisition with your own hardware. Take a look at the example code provided in my other community example post: 1. Simulating an EEG using the Biomedical Toolkit for LabVIEW.
The NI LabVIEW Biomedical Toolkit
The NI LabVIEW Biomedical Toolkit can be used for both educational and research related purposes and includes functions for Biosignal Acquisition, Biosignal Measurements, File I/O and Medical Image Processing. With the Biomedical Toolkit, you can take EEG, ECG and EMG measurements easily and effectively and display their waveforms in LabVIEW.
(Figure 1. Biosignal Measurements palette of the Biomedical Toolkit)
Coding in LabVIEW
The following image shows the coding used to acquire a real world EEG waveform and perform an FFT on the data so that we can view it in the frequency domain. Typical EEG frequencies range from 0-30 Hz, with expected amplitudes of 10 uV - 100 uV when measured from the scalp.
(Figure 2. LabVIEW snippet of Block Diagram coding for the Real World EEG Example VI)
The Biosignal DAQ Express VI
Configuring the Biosignal DAQ express VI involves setting the the expected input range to the DAQ device and sample rate. You can also set the sensor scaling prior to taking your measurements in order to vary the expected input range of the device. For example, I have used the Vernier EKG sensor scale to limit the input range to a millivolt scale.
The express VI is very similar to the DAQ Assistant express VI as it includes options for setting which hardware channels to use and selecting the acquisition mode of the device. Take a look at the following Configure Biosignal DAQ dialogue box to familiarize yourselves with the express VI set-up.
(Figure 4. Configuration Dialogue Box for the Biosignal DAQ express VI)
EEG signal notes
Acquiring your own EEG data
Provided you have the necessary hardware, all that is left for you to acquire your own EEG data is to ensure you download the Biomedical Toolkit from the National Instruments website:
LabVIEW Biomedical Toolkit Download Web Page
Try creating this simple program from scratch. If you have any problems you can download the attached VI or use the Block Diagram snippet in Figure 2 of the document - Enjoy!
Uses of EEG
There are many reasons for taking a person's EEG. EEGs are useful in diagnosing brain tumors, encephalopathies and epilepsy. However, brain waves can also be used to control real world devices. Take a look at the following link to get an idea of how EEG can be used to control robots:
Further development of this page
If you have any suggestions to improve this page or if there is anything not included on here that you would like to see, let me know and I will do my best to accommodate these changes.
Amazing! Really great work Ben, well done
Hello I wanted to know what types of devices could be connected to the analog inputs of the myDAQ
Any analog output sensor can be connected to the inputs of the device. For example, you could use temperature sensors, accelerometers or even microphones.
okay, but I only asked for an ECG, I wanted to know if I need to create the EEG detection circuit or if there is already a sensor that allows direct connection to the myDAQ.
thanks
I am using NI ELVIS II+, NI LabVIEW, NI Bimedical Toolkit.
I want to do the EEG application based on LabVIEW.
What are the Sensor item are required to complete real time EEG signal aquisition and record the data.
Please suggest, if anybody doing this priviously.
