Example Personalities for R Series Intelligent DAQ
Reply
PXI-7841R does not found any cRIO Module
Highlighted
I have here the following hardware setup:
PXIe1071 (with Windows)  -->  PXI-7841R (Connector 1 RDIO)  -->  SHC68-68-RDIO (cable)  -->  NI 9151 (cRIO expansion chassis).
But unfortunatelly, if I scan cRIO Modules, no Module will be found.
What am I doing wrong?
See the both screenshot below:
(2,352 Views)
Re: PXI-7841R does not found any cRIO Module
this thread can be closed.
I found out the problem.
The fuse on the board was defect...
(2,274 Views)
