Example Code
Using LabVIEW and the Hokuyo URG-04LX-UG01 Laser Range Finder
Products and Environment
    Hardware
  • Instrument Control
    Software
  • LabVIEW
    Driver
  • NI VISA
Code and Documents
Description
Overview
In this example, we show how LabVIEW can be used to interface with the Hokuyo URG-04LX-UG01 Laser Range Finder.
Description
The URG-04LX-UG01 is a small, low cost, bus powered LiDAR that can be easily used to acquire fast and accurate distance measurements across a 240° range. The attached code below can be used not only for visualising a simple algorithmic depiction of how a USB device can be controlled using the NI-VISA drivers, but also can be used as API to be integrated within larger application frameworks based upon acquiring distance measurements from the URG-04LX-UG01.
Requirement
  1. LabVIEW2013 (or compatible)
  1. Download the attached file URG-04LX-UG01 LabVIEW 2010.zip.
  2. Register your Hokuyo URG-04LX-UG01 within the NI-VISA using the NI-VISA Driver Wizard. This will not conflict with the driver software provided by Hokuyo.
  3. Open URG-04LX-UG01 Main.vi. Navigate to your connected device COM port through the VISA dropdown box, and notice the default Acquisition Parameters; these are configured for a full range scan.
  4. Hit the Run button. You should now start acquiring continuous distance measurements across the entire range of the scanner populate the Distance Measurements array. By default, we are scanning the full range of the URG-04LX-UG01, including the Dead Zone; distance measurements within this area will result in a constant value which must not be included in measurement processing.
  5. Hit the Stop button to end the VI.
  6. Hit Ctrl+E to jump to the Block Diagram and view the graphical code. Each SubVI contained within the accompanying LabVIEW Project 'Hokuyo URG-04LX-UG01 Getting Started' can be double clicked on and navigated. All code is fully documented and compliant with the SCIP specifications used to control the device.
NI Snippet
It is recommended that when analyzing the LabVIEW code, you also have access to the accompanying datasheet for the URG-04LX-UG-01 which outlines the specifications of the SCIP 2.0 communications interface.
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
Comments
harindervirk
on
Edit: I was getting error: Invalid buffer mask specified but I followed this white paper instead and it worked.
