This example is based on niScope EX Configured Acquisition.vi that installs with the NI-SCOPE driver. For information on front panel inputs, configuration, and external connections, please refer to the VI documentation for that example.
This example demonstrates the use of a start and reference trigger together. The digitizer in use will only accept the reference trigger after the start trigger has been received. Thus, a common use case is setting the digitizer to wait on a reference trigger from a repeating source, such as a pulse train or sample clock. The user can then decide to use the nth pulse in a series of pulses, or trigger from a sample clock pulse after a start trigger has been received from another source.
This example also uses an external reference clock, however this is optional. To remove reference clock functionality refer to step 7 on the block diagram.
Software
LabVIEW 7.1 or compatible
NI-SCOPE 2.9
Hardware
PXI-5124, PXI-5122, PXI-5621, PXI-5911, PXI-5922, NI PXIe-5122, PCI-5112, PCI-5114, PCI-5122, PCI-5124, PCI-5911, PCI-5922, PCI-5102, NI PCIe-5122, DAQCard-5102, PXI-5102, PXI-5112, PXI-5114, PXI-5620
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
