From 01:00 AM CDT Saturday, June 10 - 04:00 AM CDT Saturday, June 10, ni.com will undergo system upgrades that may result in temporary service interruption.
Example Code
Use Disabled Channel for a Trigger on PXIe-5162 or Other NI-Scope Device
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
This example is a modified version of the Configured Acquisition example available for NI-Scope devices.
Description
This application allows the user to set up a disabled channel for use as an analog reference trigger source (edge, window, or hysteresis). This example is most useful for NI-Scope devices that do not have an available Trig connector on the front panel of the device. However, this functionality is generic enough to be used with any NI-Scope device. For more information on this functionality, please refer to the Knowledge Base article entitled Using a Disabled Channel to Trigger Acquisition with NI-Scope.
Requirements
  1. LabVIEW 2012 (or compatible)
  2. NI-SCOPE
  1. Compete device configuration, like Resource Name , Channel(s) to Acquire and Trigger settings..
  2. Run the application
VI Snippet
Peter E
