Example Code
UT Austin ADSL2 Simulator
Code and Documents
Description
This freely distributable toolkit provides a graphical user interface and functions in LabVIEW to simulate a discretized multicarrier wired communication system based on the ADSL2 standard.
This freely distributable toolkit provides a graphical user interface and functions in LabVIEW to simulate a discretized multicarrier wired communication system. The structure and default parameters of the transmitter, channel model, and receiver follow the ADSL2 ITU-T G.992.3 standard, which provides asymmetric two-way high-speed wired data communication. The downstream direction indicates the higher data rate direction, and the upstream indicates the lower data rate direction. The simulation is in National Instruments LabVIEW software. A standalone executable of the simulation that runs on a PC without needing a LabVIEW license is also available in the releases.
Other requirements:
Modulation Toolkit 3.0
