Example Code
Three Ways to do Mathematical Analysis in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This document shows three ways to do a simple mathematical analysis using LabVIEW.  The three methods shown in this example are:
  • Using the LabVIEW Math libraries (simple example ODE LabVIEW.vi)
  • Using MATLAB Script Node (simple example ODE MATLAB.vi)
  • Using MathScript Node (simple example ODE MathScript.vi)
If you are interested in a comparison of some of these methods, particularly to see the differences between using the MATLAB Node and the MathScript Node, see this page: Moving to MATLAB Script Nodes from MathScript Nodes in LabVIEW
Hardware and Software Requirements
Required software for Windows:
  • LabVIEW 2018 (32-bit) or later
  • LabVIEW MathScript Module (32-bit) or later
  • MATLAB 2018a or later
No hardware required.
Installing the examples and setting the path in MATLAB:
Place the following three example benchmark VIs and supporting script (from the Example Benchmarks for MATLAB Script and MathScript zip file) into the Documents > LabVIEW Data folder on your Windows computer:
  • simple example ODE LabVIEW VI
  • simple example ODE MATLAB VI
  • simple example ODE MathScript VI
  • secondord.m
Also make sure that you add the path for the LabVIEW Data folder to your MATLAB environment on the same machine.
Running the example VIs:
You can run each example VI and observe the results.
MATLAB Script node
MathScript Module
