Overview
This example demonstrates how to source current and then measure voltage and measure current on the same set of channels.
Description
This example demonstrates how to source current and then measure voltage and measure current on the same set of channels. This VI takes a starting current value and an ending current value and performs a sweep based on a user-specified increment. For each current value, it configures and applies the specified current on the channels passed in the Channel List control. The PMU attempts to force the specified current while limiting the voltage to the specified upper and lower limits. The Source DC Current and Measure Sweep VI then graphs Current vs. Voltage for each channel on a XY Graph.
This VI is meant to be used with the PXIe-6556 High-Speed Digital IO device with a built in PPMU.
Requirements
Software
LabVIEW 2012 (or compatible)
NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
Hardware
NI-HSDIO devices
Instructions
1. Select the Resource Name.
2. Run the VI.
Hi, i´m a physics student in a federal university from Brazil, and i´m trying to do a similar program, the only difference is that i´m using VISA, because i haven´t got this specific driver that you used in your program. Could you enlighten me about it? Thanks!
