Overview
Demonstrates how to use NI-Sync along with a Timing & Synchronization board (PXI-6652 or PXI-6653) to route a clock to the ClkOut terminal. The clock signal's frequency is then measured on PFI0. This program confirms that the ClkOut signal is present and that its gain is enabled.
Description
This example utilizes the ability of the PXI chassis to route signals along its backplane to an external destination. Using the Timing and Synchronization Board provides a more accurate clock for measurements and generation. Once the source is chosen as the backplane clock, it can be sent to the Timing Module. The external signal should read 10MHz.
Requirements
Software:
VI Snippet
Very nice!
