Example Code
NI-IMAQdx Grab and Save to AVI
Products and Environment
    Hardware
  • Machine Vision
    Software
  • LabVIEW
    Driver
  • NI Vision Acquistion Software
Code and Documents
Description
Overview
This example demonstrates how to Grab and Save to an AVI format by using IMAQdx.
Description
You need to specify the frame rate that your camera will be acquiring at, as this will adjust the playback rate of the AVI video produced. As the while loop iterates, it adds every grabbed image to the AVI video as single frames, once your acquisition is complete the AVI file will playback at the pre-set frame rate.
  1. Select your camera from the Session In control on the Front Panel
  2. Set your desired Frames Per Second
  3. Run the VI
  4. Specify a path to save the AVI file
  5. Press stop when you are finished with your acquisition
Requirements
Software
LabVIEW 8.6 "or compatible"
NI Vision Acquisition Software 8.6 "or compatible"
Hardware
Compatible camera
Please see the following link to determine if your camera is supported
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Thank You
Eric Reid
Motion R&D
Comments
Todd S.
NI Employee (retired)
on
Great stuff!!!
Todd S.
LabVIEW Community Manager
Qia.sky
Member
Member
on
But how can I add sound or audio acquired by microphone to the avi file, then I can play the avi with sound?
http://www.vitst.com
Virry Test & Control
LabVIEW Certified Developer
Julio_HDT
Member
Member
on
Hi, its so cool. but any body knows how to record in others formats? because a video 1 min = 200 megabits
