Example Code
Modifying The NI 6587’s CLIP for 1:7 serialization ratio (generation and acquisition)
Code and Documents
Overview
The available CLIPs for the NI 6587 LVDS FAM perform serialization/deserialization with a ratio of 1:10 (ChannelSerdes) or 1:6 (ConnectorSerdes). Sometimes applications require different serialization/deserialization ratios (e.g. CameraLink – 1:7) for which the CLIP can be modified.
Description
This tutorial describes the steps in detail which are required to achieve 1:7 SERDES ratio with the NI 6587 LVDS FAM. During the modification, the clocking of the acquisition is also fundamentally changed to support sampling controlled by a frame clock.
See project documentation:
     - Instructions.txt
     - NI 6587 Clip Modification.pdf
Requirements
Software
     LabVIEW 2013 with LabVIEW FPGA
     NI FlexRIO 13.1
     NI FlexRIO Adapter Module Support 3.4
Hardware
     NI 7965 FlexRIO
     NI 6587 FAM
Contributors
