Example Code
Laser Displacement Sensing and Data Logging with NI USB DAQ and LabVIEW
Products and Environment
    Programming Language
  • LabVIEW G
Code and Documents
Third-Party Code Repository
Some users manage their code in repositories outside of ni.com. Use your best judgment when following links to third-party sites. https://www.micro-epsilon.in/fileadmin/download/products/cat--optoNCDT--en.pdf
Description
Laser displacement sensors are non-contact devices that measure distance, position, height, or thickness with high precision using laser technology. In this example, the optoNCDT 1910 laser sensor (model ILD1910-750) is used, connected via a 17-pin plug-in cable to an NI M Series USB DAQ device. The system acquires analog voltage output from the sensor, converts it to displacement (mm) in LabVIEW, displays the results in real time, and logs the data for further analysis.
This setup is ideal for applications requiring accurate, high-speed, and non-contact measurement such as quality control, automation, or structural monitoring where physical contact with the target is not possible or desirable.
How to Use
Hardware Setup
Step Action
1 Connect the sensor’s analog output (typically 0–10 V) to an analog input channel on your NI USB DAQ (e.g., Dev1/ai0 or ai20). Use the 17-pin connector cable as specified by the sensor manual.
2 Ensure the sensor and DAQ share a common ground.
3 Power on the sensor and DAQ device.
 Run and Observe
  • Start the VI. The graph will show real-time displacement.
  • The data is scaled to mm and can be logged for analysis.
  • Use the Stop button to end acquisition and clear the DAQ task.
Additional Information
Modify for Other Use Cases
  • Multiple Sensors: Add more channels in the DAQmx Create Channel VI.
  • Different Ranges: Adjust scaling factor and voltage range for your sensor.
  • Event Logging: Add logic to log only when displacement exceeds a threshold.
  • Continuous Monitoring: Use continuous sample mode for long-term data collection.
Contributors
