Description
Description-Separate-1
The topology file describes the hardware signal routes available on the SET-2010 and SET-2310. There are 4 files that contain all the possible configurations of the SET-2010 with SET-2310 daughter cards. The topology can be loaded from the JSON files when using the SLSC-Switch Driver or the Routing and Faulting Custom Device in Veristand. This allows the user to query and configure nodes and routes in the hardware.
Description-Separate-2
