Example Code
ISO-8601 compliant date/time string in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example transforms the input date and time to ISO 8601 Standard
Description
This example creates an ISO-8601 compliant date/time string using various LabVIEW format specifiers. If no timestamp is provided, the current time is used.
Requirements
LabVIEW Full Development System 2012 or compatible
  1. Enter the Date and Time Part in the same format as indicated
  2. If no date and time is entered the current time will be used
  3. Select whether to show the Time Zone, Basic or Zulu
  4. Run the VI
 Wikipedia entry for ISO-8601
VI Block Diagram
 SubVI Connector Pane
**This document has been updated to meet the current required format for the NI Code Exchange. **
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
Comments
Knight of NI
Knight of NI
on
Hi Phillip,
there's a bug in your VI related to how LabVIEW numbers weeks of year. The LabVIEW numbering scheme uses US-american standard which is different to ISO8601! You can test that with a date like Jan 3rd 2010 (as noted in the linked Wikipedia entry, section "Week dates")...
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Active Participant
Active Participant
on
Wow! Thanks for catching that. I'm gonna try to fix that up, but it seems I have to do more of the work that LV should have done for me
Knight of NI
Knight of NI
on
Hi Phillip,
go here: http://forums.ni.com/t5/LabVIEW/Date-time-conventions/m-p/172136#M101086 to find a correctly working ISO-Week VI!
Active Participant
Active Participant
on
GerdW, I used the example you referenced. I changed the design of my VI to use a state machine, and had to add some logic to the referenced VI to update the year.
Lesson learned: LabVIEW 'to UTC' ≠ ISO-8601 compliant
Active Participant
Active Participant
on
The VI I created offers many variants of an 8601 string, but you can use the following format string with "Format into String" and "Scan from String" to persist an 8601 UTC timestamp.
